Thersom1948
- Apr 16, 2020
- 58
This feels like an obvious newbie question:
1. The Growatt 24V SPF 3000TL LVM can support up to 60A AC input charging.
2. The Growatt 24V SPF 3000TL LVM can support up to 3000W @ 120VAC, or about 25 amps output.
How can I utilize this in a stand alone system? Meaning this will not be permanently grid tied (build is similar to the famous "hand truck" build video).
Problem 1: My house standard outlet circuits are only 20A (Except for Dryer, Stove, Hotwater).
Problem 2: The only AC stuff I can find at the hardware store claims a max 20A - This includes outlets, extension cords, etc. I can't even find a heavy duty power-strip that claims to rate to more than 20A. Unless you move up to dryer/stove speciality plugs, and even those are only 30A max in single phase.
In the build video Will is charging his at 40A with just a regular extension cord (that's probably not rated for 40A?) Does his house just happen to have 40A wall outlet circuits?
Am I just limited to 20A charging and 20A discharging in order to stay in the "limits" of the AC wiring and plugs?
Thanks!
Thanks!
