Will did a video on it title is 72 dollarsI heard this smart one in a YouTube: https://www.aliexpress.com/item/32945565819.html?spm=a2g0o.cart.0.0.29953c00QDH9GK&mp=1. I am thinking about trying. Now sure if there are discussion there and see how well it works.
I understand how it feels.there doesn't seem to be a reliable way to ensure it's operating correctly.
Your charger should be set to stop charging at 3.5V. You are not getting the basics yet and should not be spouting this without that practical knowledge.. people might actually be mislead .But it also disconnect battery (B-) when cells get higher than 3.65V. Means your inverter or load is switched off when your battery is full !
You can't switch on your inverter again until the BMS turns on again. That may take long time because the cell voltage drops slowly since there is no load connected. And as soon the BMS turns on again, your PV starts charging also. Makes the cells rise quickly because your battery is full so you end in a deadly loop of BMS turns on/ off with short intervals.
Every time high inrush currents to your inverter/BMS and damage to your electrical appliances may occur.
If it started at 30 amps then its probably at 3 amps round then and 30mA gets passed through a resistor to ground so the other cells still get 3 amps and the high cell gets 2.7 amps giving the others a chance to catch up
We are talking about battery banks. In my case 16S 200Ah 48V.Your charger should be set to stop charging at 3.5V. You are not getting the basics yet and should not be spouting this without that practical knowledge.. people might actually be mislead .
It should not damage the BMS if it's well constructed and the parallel mosfets are good enough. Can you say the Daly uses sufficient mosfets with low RDSon and high voltage? Noone can look inside. It may survive a few hundreds inrush currents until one mosfet burns and the rest follows.For instance why would the inrush current to the inverter damage the BMS ? They are usually good for 10 times the rated current for a half a second or so just like your fuses. Sustained current at that rate would but its charged in a quarter second or less.
Like you said: that's the theory.The 30 mA is there for small cells and pretty useless for larger cells you might think but when your pack is getting close to full is when it comes into play. Your charge current gradually reduces as the voltage comes up .If it started at 30 amps then its probably at 3 amps round then and 30mA gets passed through a resistor to ground so the other cells still get 3 amps and the high cell gets 2.7 amps giving the others a chance to catch up .Thats the theory .
I do not agree with this too.I find Ali-express to be totally unreliable for refunds or returns . Ali baba would be proud of them . Its a punt every time you deal with them and ebay are streets ahead on problems.
How do they balance 30mA with high impedance inputs? It's more than an input.Why would a ground reference be needed while plugging in a loom which is tied to high impedance inputs?
I have had a few disputes on Aliexpress, if it is damaged you can prove it with a photo, instant refund. if they advertise false claims, that's okay, as long as it works. no refund.I do not agree with this too.
There are many unreliable Ali sellers who try to escape when they have to refund but Aliexpress does a real good job.
As you can see I have quite a lot of orders there. And many disputes over the years.
But I only dispute with good reasons and with decent evidence.
I always win the case and they return the money without much questions.
That's right. It must be very difficult for those Aliexpress people to judge about so many different products. Buyers are not always honest as well...I have had a few disputes on Aliexpress, if it is damaged you can prove it with a photo, instant refund. if they advertise false claims, that's okay, as long as it works. no refund.
Sometimes those 2 or three stars comments never get entered, Also for the supplier to get paid, you must click received, Then if you fill out the review 5 stars, Then to find out the product is crap. too late.That's right. It must be very difficult for those Aliexpress people to judge about so many different products. Buyers are not always honest as well...
So we need to provide clear evidence to make that decision more easy. Sometimes that's difficult.
But it's more than that. Buyers and sellers have profiles. The ratio buying/dispute is important. If the seller has too many disputes, bad for him too.
My last dispute is about 10 fake mosfets (15$). Chinese go far to make money. BLS sells bad batteries but even simple mosfets can be faked. How more they cost how more chance they are faked.
That's what they do: they take a cheap chinese mosfet with the same dimensions; they grind the surface flat and laser the specs of an expensive US/ EU brand. They sell it to 70% of the western price. At first sight nothing wrong with the product, it acts as every mosfet but of course the specs are not the same and under power they heat up or blow up faster.
When you discover that something is wrong with the product and not with your schematics, you give 5 stars already and the dispute period is over.
Aliexpress stars are not very reliable. I only read the 1-3 stars comments, more chance they are true.
Pictures: flat grinded mosfet, nicely remarked.
But: original parts are marked with a strong and fast laser because they have to name millions of parts. So the characters are written in one pass.
Chinese counterfeiters use a cheap laser and have to write the characters in 2 times to get enough depth and width. It is slow and not precise enough and burns holes when it stops in a character. So, no doubt it is fake.
Such parts may be used in BMS, etc , hard to say.
We should all buy more local quality but it's so cheap in China...Bangwood site.. much lower on the standards
