Yep and I'm not reading the posts anyway.I guess we are going off topic
Strange that you still reply themYep and I'm not reading the posts anyway.
HiI do not agree with this too.
There are many unreliable Ali sellers who try to escape when they have to refund but Aliexpress does a real good job.
As you can see I have quite a lot of orders there. And many disputes over the years.
But I only dispute with good reasons and with decent evidence.
I always win the case and they return the money without much questions.
Yes right , but with RDSon of +- 5mohm that should be 12W at 50A (I²R) , divided by 7 mosfets is less than 2W per mosfet. Since I did not use more than 50A load and charge, I guess they used very cheap mosfets with high RDSON because plastic will not melt from 2W, certainly not with 2.5mm alu heatsink on both sides.Heat results when running high current.
I bought such 16S balancer and I thought first it did not work as well. Actually it does not start balancing at 0.1V difference as advertised. There must be more than 0.2V diff. It does not balance until 30 mV difference, it's more 70-50mV.I am ordering an active BMS. https://www.aliexpress.com/item/33002903687.html?spm=a2g0s.9042311.0.0.73d74c4dAhEQYQ. I hope it will go hand in hand with Daly BMS. Will had a good review on it. David had a bad review:
