Hi all,
The renogy manual is unclear. It states that the max. solar input voltage is 25V. I have 5x100W and 1x50W panels. I was planning on wiring every other panel in series (thus yielding 3x 24V panels) and having these 3 panels go to the charger. This would keep the current below the lot of 25A and would mean I could use smaller cables. However, the voltage limit on the charger is 25V. I am aware that when solar panels are in the sum the output voltage increases. Will I be ok to wire my panels as described? Many thanks in advance!
