Sorry for the delayed reply I am a newbie to forums and solar I have received my panels the freight company put the forks of the forklift through the bottom panel and dented another one. Somehow I didn't pay attention to the sides of the panels having some damage as I did the one with the glass being shattered and I only marked (1) down as damage on the bill of lading. It wasn't till after the driver left that the evening sun was shining on the side of the stack of panels I noticed one had a pretty good sized dent in the aluminum frame. I did contact go greenman solar the next day and they did not hesitate and said they would replace the two that I had noticed the shattered panel and dented panel. then the other day when I got a chance to do some testing and I seen 3 panels with deepish rub / scratching on the other side of the stack like from a load lock. As for the (10) panels I got a chance to test the short circuit current an open circuit voltage laying flat on the deck of a trailer in Iowa on a sunny end of February day between noon and 1:40 my results were Open Circuit Voltage (Voc) 88v-82.7v and then placing a sheet of plywood over the panel shorting the leads together then uncovering and testing with a Klein Tools CL800 Digital Clamp Meter to take the reading, then re-covering to unplug, my Short Circuit Current (Isc) results for the (10) panels tested was between 4.8A to 4.13A. The two replacement panels shipped via different company is scheduled to be here this afternoon.
