I have 9 panels ready to mount -
and I'm considering buying a Growatt 48V SPF 3kW 3000W LVM-ES
If I'm reading this right, the Growatt has a start-up voltage of 150v and a max Voc of 250v.
So how can I wire up 9 panels?
3s3p would only give 133.2v max, not enough for startup.
2s4p would get 177.6 which works, but means leaving one panel out of the system
What if I get one "oversized" panel to make 2s5p?
Can I get something like this (sunpower photo below) nearby, making one string 222v and the other 241.8v, and the current is larger on this odd panel than the others?
All of the examples I've found for mixing panels have had the odd panel being lower specs than the rest. What about using a higher-spec-ed panel as the odd one? If I'm fine with the maximum output being in line with the other lower panels, losing the higher capacity from that one odd panel but getting the max out of the rest of them, will this work?
Thanks!
9 panels' specs:
SPF 3000TL LVM-ES 3kW 120V 250V Solar Voltage, 48V Battery parallel
SPF 3000TL LVM-ES 3kW 120V, 120 to 250V Solar Voltage, 48V Battery OPTIONAL (batteryless), up to 6 in parallel for single , split or 3 phase output growatt BEST SOLAR FOR HOME PEROVSKITE INVERTERS FOR PHONE PHOTOVOLTAIC DC TO AC INVERTER SOLAR ROOF JACKERY 1000 1KW 1000W SOLAR SUN POWER SOLAR...
www.signaturesolar.com
Thanks!
9 panels' specs:
