Hi All
I'm relatively new and still learning and been reading a lot on this forum, but a few things always crop up i don't quite get! I'm getting close to installing my system and have my hybrid inverter which has the following specs .......
i have found some solar panels with these specs
Pmax 410W
Imp 8.47A
vmp 48.41V
isc 8.95A
voc 60.32V
I'm not 100% on the exact definition of all of these, but i cant quite make the maths work with these panels i assume i can only get 8 panels in series (8 x 60.32 = 482.56) but in parallel 8.95 x 2 = 17.9 amps, is this not dangerously close to the limit? how close can i go, and does it even help? I'm looking at 18 panels which i assume is the limit 4s2p on one input and 5s2p on another, 19 panels would be under the 8000w limit but allowing for a could weather and I'm not sure how to wire that is that even possible?
id really appreciate the help as i may be able to pick those panels up this weekend and im struggling to get my head around it, many thanks in advance
- Nominal battery voltage: 48V
- Continuous power output: 8000W/8000VA (220-240V AC)
- Surge power: 16000VA
- Output frequency: 50/60Hz
- Output waveform: Pure sine wave
- Maximum solar input power: 4000W per input (8000W total)
- Maximum solar input current: 18A per input
- Maximum open circuit solar input voltage: 500V (open circuit)
- MPPT solar operating voltage: 90V - 450V
- Maximum solar charging current: 80A
- Maximum mains AC charging current: 120A
- Maximum combined charging current: 120A
Pmax 410W
Imp 8.47A
vmp 48.41V
isc 8.95A
voc 60.32V
