patfinegan
- Jul 31, 2022
- 14
The MOES Dual Power Controller 50A 5500 Watt Automatic Transfer Switch has four inputs: Public Power, Output, Inverter and Battery. I purchased the unit to supply backup power from Con Edison (my electric company) to some security devices in a vacant home (modem, router, POE injector, cameras) that I power using solar. The solar panels are two Renogy 100 W panels in parallel, and the battery/inverter/generator is a Jackery Explorer 1000. The back panel of the Jackery has the following sections: Input (for the solar panels or other off-grid energy sources), AC Output (three 3-prong 110 V outlets), and DC Output (USB-A, USB-C and 12V,10A car outlet).
The battery has never run low, but I have not yet encountered multiple days without sun. Also, because the Jackery is the backbone of a vacant home's security, I want automatic backup power. Before proceeding further, however, I want to wire the MOES ATS correctly. Public Power is self-explanatory. So is Output. But I want to make sure that I wire the Inverter and Battery inputs correctly. My hunch is that the AC Output from the Jackery is the Inverter input for the MOES, and that the DC Output from the Jackery is the Battery input for the MOES, but these are just hunches. Can anyone with genuine experience or expertise corroborate this? Also, the battery input should be 12V10A or USB? Thank you in advance for helping a complete newbie.
