TimC
WI/UP Border
- Apr 17, 2020
- 139
Edited title to correct battery type...
I'm building a 48v 150ahr LiFePo4 bank with 75aHr Eve cells. I have two 60a, 16S BMSs.
My concern is mostly weight as it will be living in a small, somewhat confined area.
Would you build two 16S 75ahr batteries, each with its own 60a bms and parallel them to make 150ahr? Or would you build one 16S2P battery with one 60a bms? It's essentially the same except for the weight and absence of one bms.
I'll never draw over 1500 watts 120v from the Growatt hybrid inverter. The 16S will weigh about 75lbs. The 16s2p will double that weight.
Your thoughts.
Your thoughts.
