gnappi
- Apr 14, 2021
- 25
I have a decent 8500 watt genset that has worked out for the last 12 years for me after storms and losing our power. The issue was and likely will be keeping the Genset running and / or getting gasoline. What I use it for is my refrigerator, and two 6000 BTU window AC units.
What I'd like to find out is whether or not given my current and easily expandable system is reasonable to think I can duplicate my genset duties. So I bought a Killawatt meter and ran my two appliances to get my expected loads.
My refrigerator 1.15Amps with compressor and fan running. It runs infrequently and in standby drops to zero. Even if Genset is running I unplug it overnight
Two 6000 BTU window AC units @ 2.8Amps each After a hurricane they run continuously with exception on cooler nights I run AC fans.
Minor conveniences like two small LCD TV's @ less than a half amp each and some LED lighting.
NOTE, the system is NOT grid tied.
My current system panels are 575 watts (space left to expand to 775W total) with a 60A MPPT controller.
Battery system is 12 volts (2x100Ah Marine deep cycle, easily expandable to needs)
I have one 5000/10000 watt 12 volt inverter and one 12 volt 1000w inverter
Have parts / pieces to add ground mounted panels at 300 watts of panels (easily expandable another 400 watts to 700w total) with 60A MPPT controller.
So, given I'm stuck with 12 volts (cast in stone, 24v/48v ain't happening) and no place for additional panels but ample space for batteries, what would I need to sustain some level of comfort at night with my two AC units running 24/7.
