I have worked in hurricane relief, most of the ruined solar panels I have seen were from flying debris
Same here. 10 to 40 lb branches hurled at 40 to 80 mph. I had 15 cement flat tiles broken up on roof. In 2004 my 12 foot expanded screen dish on 4" thick wall galvanized pipe pole set in concrete was snapped over.
Getting gas afterwards can be a pain. I considered having light weight flex panels to spread out afterwards but still too expensive to have enough panels to make a dent in gas consumption. I get the most out of gas used by running gen at 75% rated load to charge batteries for several hours twice a day. Most people are running 5kVA noise makers averaging 500 to 800 VA power output.
I was close to an inspector the other day and someone joked "well, that's hurricane proof now!" The inspector looked at it and said, "Hurricane resistant... no such thing as hurricane proof".
that is why you dig a rectangle into the ground, make a recessed cement base and put a foldable frame into it.
you add a cover that can be bolted in several places. (even some steel strip to reinforce cover.)
I had that same idea for ground mounting. The only thing is that you have to make sure that when the cover goes on the whole thing is completely water proof or the panels may get flooded.that is why you dig a rectangle into the ground, make a recessed cement base and put a foldable frame into it.
if you take care to fold the panels into the case (hurricane rarely came by surprise) , let it go , unfold the panel again, there should be no surprise.
it is minimal work and should last forever.
you can take occasion to mount led panels on the frame so you can eventually work at night.
if the house is flat roof style, you can build rectangle with concrete brick, so the panels can be layed flat on the roof, inside the rectangle
same principle with a cover (plywood) bolted or secured with bars.
There were a LOT of shipping containers blown all over the place, and that pretty much spoiled the idea for me of buying one, and putting an array on top. Still considering the overall idea, but with minimum 30" cement SonoTubes at all corners at least 6-7' deep, with embedded steel plates, and weld the container down.
