Ampster
Renewable Energy Hobbyist
Sorry. My system goes to 100% almost every day so I am not concerned about drift. When I say 100%, that is relative to my CV setting of 3.45 volts per cellMaybe @Ampster has drift setting advice.
They're Altran Magnetics from Digikey.I think I missed what the contactors are and where from?
That's what I use too...Really filling out here in this box now, getting cozy.
I've built a bit of technical humor in, that ceramic lamp base there is my incandescent lightbulb precharge circuit. Pros: Visual indication of precharge activity. Cons: If the light bulb filament ever burned out then automatic precharge would fail unrecognized, the Orion only allows for a max precharge end amps check, and not a mid precharge min amps.
If a second DIY battery bank gets added to this system, the lightbulb will have to go for a more space saving resistor.
Higher charging current definitely charges the cells more unevenly. I fiddled with my charging to just charge to full by the end of the day. My SW4048 dialed back to 35% charge.It makes me hesitant to continue applying the big charger and I might just start with the little charger instead.
What kind of charge voltages are you running? The 2300W here is a simple CC/CC power supply out of the box. But they sell a programming adapter that can apply 3 stage charge profiles. I'm waiting to see if I'll need that for my purposes. The goal of the system eventually is that this power source will only be a backup, catching the battery at 20-40% or so, and only MPPT will be taking it to 100%.Higher charging current definitely charges the cells more unevenly. I fiddled with my charging to just charge to full by the end of the day. My SW4048 dialed back to 35% charge.
I have plenty of battery so don't need to top off completely.
Nice and do you find it reliably gets into balancing range that way? What BMS start balancing voltage are you using?Its pretty conservative.
On one battery I have a misbehaving cell so am trying to make it work until I get a 280Ah replacement. Just knocked down balance voltage to 3.35V this morning.Nice and do you find it reliably gets into balancing range that way? What BMS start balancing voltage are you using?
