hwy17
Anti-Solar Enthusiast
Odd though, I don't have an 80% drift point configured, so I don't know exactly what logic did that.
I hand checked them for warmth and they're all cold. I torqued them by feel and I'm hesitant to mess with them unless there's a problem. Could be sense harness but resistances are all .50 at rest.I would double check that all connections are torqued to the same values.
Is this also potentially the sense harness resistance? If it's the sense harness resistance, I wouldn't worry that much.
I have an inch pound torque wrench but I also have an ingrained superstition from working on dirtbikes not to put a torque wrench on a 10mm bolt head. I have snapped bolts that way and never snapped one by feel. I will consider giving this bus bar a check and snug though if it's consistently higher resistance.IMHO, get a torque wrench. You have too much invested to leave out this comparatively inexpensive tool.
Charger kicked on. They say a battery is only either charging or discharging, but they switch back and forth between the two very fast.
Above ground? I have an 18' round.1hp 120V pool pump
Hot tub. I added an external pump, filter and natural gas heater in a little (3ft cube) sound-proofed out building. As much as i love a gas fired hot tub, i miss the days of cheap NG.Above ground? I have an 18' round.
Hey it's still cheap compared to electricity, but maybe not solar.Hot tub. I added an external pump, filter and natural gas heater in a little (3ft cube) sound-proofed out building. As much as i love a gas fired hot tub, i miss the days of cheap NG.
