sunshine_eggo
Victron's little biatch
5-6mV difference at 3.40+ correlates well with top balance.
It would be extra satisfying to whip cell 7 into perfect alignment, but I know we're actually just looking at this super zoomed in. If it could be zoomed out, it would look like full consolidation. And, when it's doing this under load .007 is already going to be a tight target.5-6mV difference at 3.40+ correlates well with top balance.
Cell 7 was low in the initial balance too, so I think it may just be it's original state of charge still showing through, and not a problem with the cell.
Hey! Thank you for reading.Greetings,
I am very familiar with Orion BMS2. Not the junior. There must be a HW difference as the junior appears to measure in groups of 8 and not 12 like most BMS chipsets. Sofware looks the same.
The drift points are just to force the SOC reading to show whatever you want. I would keep the default for your cells.
True DeltaV is better checked at high SOC. less than 90% can make DeltaV look better than it is.
DeltaR is not good. Dielectric grease between busbars is a good idea. If DeltaR stays high I would swap out the cell. The sense wire resistance does not affect this.
The resistance chart needs to be populated with the correct cell resistances. Will prevent CCL & DCL from being reduced.
The Orion only balances the individual cells at a fraction of an Amp. <0.5 I think. fine with 20Ahr, will take days with 200Ahr.
I would only balance if a cell is above 3.5 with a max of 3.65. The fastest way to balance with Orion is to set the charging current at an Amp or less.
Cheers,
Iain.
PS, Cell #10 is the weak link.
Yeah I have some canbus messages that I might be able to get to shutdown my inverter, but otherwise the only option and the only currently enabled option is for contactors to open. I'm relying on my high DCL and CCL only to open the contactors in an extreme fault scenario, if the 150 amp fuse has somehow not already blown.Hi,
I was able to use CCL/DCL over Can. Shame you cannot.
it's a good idea to set DCL/CCL so you can set conditions for the contractors to open under fault conditions. I see you have set this.
I would initially charge to 3.65v so that DeltaV was more informative.
I would relocate the weakest of the cells to the end of the string & have the end of the string easiest to get to for cell replacement.
I do like the Orion BMS SW.
I wonder if I can paste a profile? Nope. LOL.
Cheers,
Iain.
Hi,Drift I'm gonna have to learn as I go. I think it's gonna be a while of not trusting my SOC calculation since you're basically designing the calculation yourself. Maybe @Ampster has drift setting advice.
Hi,Yeah I have some canbus messages that I might be able to get to shutdown my inverter, but otherwise the only option and the only currently enabled option is for contactors to open. I'm relying on my high DCL and CCL only to open the contactors in an extreme fault scenario, if the 150 amp fuse has somehow not already blown.
Contactors also react to high and low cell voltages of course. Also expecting those to never have to open in normal operating conditions.
I'm gonna keep working with 3.437 to try it out, it's kind of my pet project to trial single voltage charging in home storage applications - absorb and float and balance at 55v even.
I probably won't be re arranging since my case is so hard to work in. Luckily 10 is already in a more accessible position.
Do you have any advice on finding resistance factors for the EVE 304's? I'm a bit lost on that, and just relying on my uncalibrated figures as a delta indicator to point out the odd cells, like 10.
Have you ever looked at Nuvation or FoxBMS? I think I will try Nuvation on my next build. They are a north american commercialized version of FoxBMS.
They do, I just never did any proper calcs on 1/4" x 1" 6011 bar to compare it to wire. I gave it the seat of my pants certification for 150 amps based on the look of it.Curious as to the thermal dissipation of the bus bars. Why wouldn't they present the same or less resistance as any other cabling?
I used two of these pricey things: https://www.digikey.com/en/products/detail/panduit-corp/CESUM3-D12/16995694What did you do again?
... is that like a solar flareSystem's getting a first good workout in a light heatwave.
Yeah it's like that but with infrared, causing an intense heating of the skin and any other surface it lands on. I believe they call it "strong sun" in the UK, and they get on planes to go look for it... is that like a solar flare![]()
Thanks for the reminder, cause I honestly usually forget they even exist here, in between the times I'm reminded of it. Haven't seen one yet ever before.Watch out for rattlers. Seen more in the last week than I have in the last ten years up here.
Thanks. I forgot about how these create varying resistances.Note how horizontally, you only have one bus bar connecting parallel cells, but when you transition vertically to reverse direction, you have two.
I don't recommend this. It creates imbalance in those 4 cells.
For the single interconnect between the two halves, I would try to make that resistance the same as the other single interconnects.
