1201
Solar Wizard
I understand your point that hybrids are expensive. This was true last year when 18kpv was $5k and 6000xp was 1500. Now there are several hybrids in the $2500 range.You can easily put a Micro Air soft start on the AC. I’m running my 4 ton with a 6000XP which saves a ton over a hybrid. Also, you don’t have to power the whole house and charge an EV on the off grid inverter. He has a subpanel already that he can tie into. I’m running a subpanel, pool pump, AC, blower fan, and have the microwave and dishwasher tied in for when the grid goes down. Of course every one’s usage is different but if measure it with a clamp meter or Emporia Vue, you can make a wise selection on critical loads and where the big savings are on one’s utility bill. Our power went out on the 4th for four hours. Most of the homes around us have whole home generators they did not miss a beat. We did not either and far a fraction of the up front cost and expenses. In the greater Houston area, you just need AC in the summer and be able to keep the fridge(s) and freezer(s) going and a few lights in case of an extended power outage.
Hybrids are nice. If someone gave me one, I’d install it but I would not pay the premium for it. But that’s just me. Your situation could be different.
It looks like “Offthewall” has a similar perspective to me on post #47. You might want to disagree strongly with him
Do you understand my point that with an off grid inverter, anything that's not connected to that inverter is always on grid?
In the ops case he has a free night's plan so those loads not on the off grid inverter are going to be consuming very expensive power during the day vs using a hybrid inverter where he can use all available power for all circuits?
Is your have to install two or three easy starts, are your really saving money over a hybrid?
