lamberStye12
- Oct 29, 2021
- 4
Hi, I did some searching around the forum and I think I need a hybrid inverter my situation but when I reviewed the spec sheet of a few inverters I still wasn't sure if they supported my situation. I am hoping you could recommend a few inverter models based on my situation. I will probably discuss further with the inverter companies once I have 2-3 options to choose from.
So the subject is fairly clear on my config but to amplify, I have 6kw of existing solar with colocated enphase m250 microinverters terminated at my 100A split-phase AC main panel in several breakers. I will likely increase the solar in the future. I don't have/desire a critical loads sub panel. I will use a 48v lfepo4 backup battery. My goal is for the battery to act as a temporary whole house ups with solar assisting if sunny.
The issue that always trips me up when I decide to invest in this is that the solar is ac and shuts down if the grid goes down. If an inverter restores this ac power temporarily via the battery, the solar will sync with ac and start up again of course. However the inverter must be able to manage the situation where the batteries are fully charged, it's still sunny, and the house isn't drawing any load by shutting down the solar in some way (disconnecting breaker or moving ac signal out of phase).
Anyways, looking forward to your feedback on this one and hoping a few hybrid inverters exist that handle this config specifically.
