First Post! I'm starting this thread to get feedback on an upgrade to an RV hybrid LA+Lifepo system I am thinking about. This is all new to me and am trying to learn as I go. This forum has been really helpful. I'm in the planning phase. I've been researching all kinds of possibilities and recently stumbled across the idea of a hybrid LA-Lifepo system(video link). It seems like an great way to not carve out my current set-up, simply add to it, with the potential to remove the upgrades should I sell the RV down the road.
Current set-up:
RV is 2015 Itasca Navion on '14 sprinter chassis.
I ordered 4 of the 280 ah cells from alibaba(generally following this guide), with the 120 amp smart bms. I like the idea of a milk crate battery that I can add/remove easily to the existing system. My total capacity in the hybrid system will then be in the neighborhood of 380 ah. Based on my usage, this is a high reserve. The batteries would only be charged by the solar panel and converter when on shore power/generator.
Some of my initial thoughts and questions on this potential hybrid system:
Current set-up:
- 2 GC2 Interstate 6 V batteries in series for 12V
- 30 amp SRNE mppt solar charge controller and 300 watt huwai(sp) roof mount single solar panel
- solenoid charging from vehicle alternator
- Progressive dynamics battery charger(non-Lithium) powered via shore power or onboard generator.
- Based on my current understandings, I will disconnect the vehicle charging via the solenoid to avoid potential problems with high drain on alternator and mixed battery chemistries. I think based on my needs and large reserve, I won't need to keep this aspect and keep a "simpler" system.
- I don't really have an understanding of what the connections b/n the 2 batteries looks like. A bus bar? Other set up? If anyone has any pics that would be very helpful. I also noticed in the video mentioned above the caution needed when connecting the two batteries, which is a bit anxiety producing.
- Is there a way to set up a battery monitor(shunt) in a hybrid system to keep track of remaining capacity? If no shunt style monitor, is there another way(read cheaper) to tell?
- I'm aware of the feedback back loop that is created when adding the inverter line to the house AC panel. I noticed a separate circuit breaker for the converter and could manually flip that, or I could install a transfer switch.
- Would the hybrid system charge via the current set up? I believe the charger is connected to each end of the 6 V batteries now.
