New to this forum!
I have two systems now: 1. an 8kw system with two Fronius inverters going to a separate power meter. This system is under contract with GA Power Company, and I receive $0.096/kw for my power. 2. an 6kw system with an SMA inverter, grid-tie. I only get around $0.035/kw for my excess power on this system. I currently pay around $0.14/kw for GA Power usage. That is the real-world rate, taking the kwh consumed divided by the BILL! I built this system entirely by myself, panels averaged around $0.62/w and inverters around $0.35/w. Wiring and conduit not more than $0.10/w.
Anyway, I want to change over to a hybrid system. Everything I see shows that I must convert from high voltage to 48V. Is this still true?
The GA Power system will stay the same, of course. I will need a new hybrid inverter, and was considering the 8kw Outback inverter. That has enough power to run most of the house. Millions of questions...
I would like to hear from people who have made the switch from high voltage strings, grid-tie, to 48v hybrid.
Thanks!
Thanks!
