SolarfortheOuachitas
- Aug 1, 2020
- 43
How do you replace a heating element with a light bulb? Will it be in direct contact with the water in the tank? I’m a little unclear about how to do this. Please explain. Thank you!They output cold air. Keep this in mind when locating one in your home. Basements are a good location for them, as they dehumidify spaces. Winter time, can be a challenge, but the insulation of the tank is usually high, and they don’t run all the time, so the heat loss is handled by the earth and the heating system of the home.
If off grid, replace the element with a light bulb or the huge 5Kw element will rapidly drain your batteries...
