I can’t pair the BMS battery Felicity LUX-E-48250LG03 with the PV18-5248 PRO inverter
Maximus_Kiev
Ukraine
Hello guys.
The essence of the problem, I bought a Felicity battery, but apparently there was no need to do this. The seller assured that this battery works perfectly with MUST inverters, in fact I’ve been suffering for the second day now, crimping the wires, checking everything, overloading the inverter, but to no avail. The inverter does not see the battery. I tried to connect via CAN using contact 7.8 on the battery, I also tried using contact 3.4, it did not help. I tried connecting via RS-485, the situation did not change, the inverter also does not see the battery. Maybe someone has already solved this problem? I really hope for answers.
Thank you and have a nice day everyone!
Значок Проверено сообществом
An almost standard connection scheme between inverter and battery puts RS 485 on pins 1 and 2 and 7 and 8 with CAN on 5 and 6.
Check the manuals for your inverter and batteries, the information is usually in them.
Hello. Can u make a little drawing of this connection? I have the same problem, but I can`t communicate Felicity Battery 15kWh with Easun SMG 11kW.
