coreyzev
- Sep 18, 2021
- 41
I've read all the things, especially @FilterGuy's resource on voltages. I previously had it set according to that: Absorption: 56.8V, Float: 54.4V. But it felt like the system was acting weird when I "barely" used the battery, which is often the case, and then it either did or didn't charge.
The default for Victron for LiFePo4 batteries is Absorption 56.8, Float 54. But because we in theory want it to NOT float at all for LiFePo4, I set float to match Absorption, which in theory would cut it out entirely... but doesnt seem right. (Also I feel like FilterGuy would've said something if that were better to do).
To be clear, the main [internal] controversy here is where to put my Float voltage for the best health of my batteries which will likely be cycled frequently. But also often used along w/ a 30A 120V system.
So now I feel kinda at a loss. Components will be listed below. Would love suggestions from y'all. Thank you.
System:
Battery: DIY 48v 16s3p 300Ah LiFePo4
Inverter Charger: Victron Multiplus-ii 48v/3000VA/30-50 120V
Shore Power: 30A 120V
Current settings:
System:
Current settings:
