Hello, new to the forum,
I will try to keep my post simple
I am looking for advice on bms for a future project, I am in Philippines and trying my best to source all parts through a shopping site and in future source the materials through alieexpress or alibaba but in the meantime .... trying for a milkcrate design as my first battery
Here is the list of items I plan on purchasing
Volt meter
500 watt sine wave inverter
Bms ( need help figuring out which one )
Batteries I will use Lifepo4 Battery 4 unit LiShen 3.2V 202ah ( trying for a simple 12v setup
The only 2 areas that I need help with is
1.How do you add a simple wall charge plug device I have a bluetti ac50s I think it is called and it plugs into the wall to charge ( trying to source parts through shoppee website/app )
2. Which is the proper bms to use ( using the shoppee website/app
Additional info, I am in mainly using this for brownouts , meaning power companies shut down quite frequently, and while I like the ac50s I am limited to running the 40 to 50 watt fan for only 8 hours. Any and all help is appreciated
Volt meter
