oneandahalflegs
- Jan 18, 2020
- 38
anyone using this?
I have kilawatt,. my not so willing assistant just went back to college,. I need real data from well pump.
Interesting, let's see I only have three resistance devices in the house. washer, dryer, and dishwasher. for my purpose this sounds like it would work well.I have one. I have the solar add on, so it can tell me what I have used today and what I have produced today. It has a real time meter but the summery is only updated once an hour. It tries to figure out what loads are what, but it has trouble with resistive loads that are close to the same. Water heater and clothes dryer are often confused, which makes no sense because it can detect inductive loads. But overall it is pretty good. I can look at my solar production in real time and know how much sun is shining at my house.
It is defined. Measure phase in progress.In a similar manner, I was faced with the idea of people who are not mechanically inclined to re-fill and start a gas generator twice a day. And the overall cost of gas generators seemed to have more tank volume to cost than actual power- which was really odd.
Still, the choice was a DIY solar generator vs. a gas generator for some very specific things.
I was lucky that the time of cloudy weather was a day, so I could make a massive storage compromise on the batteries for cost reasons.
But when you finally figure out how much energy storage you need to survive 4 days without sun, then you need to look at the solar web sites to determine your nominal sun exposure during the day so that you can size your panels.
To me, the easy part is the inverter. The sum of all the loads at the same time < nominal output and the sum of all things turning on at the same time is < peak. As an engineer, you know that the odds of the latter actually happening is pretty remote, but something you can choose to protect for or not.
The last thing to really consider- do you want to use some of that sun power when you don't have emergencies? For the set up I have, I'll probably power something that is used every once in a while, but I'm tempted to add an auto switch so that I can power one of the things that is part of the emergency set.
In the end, it's just a series of information that you need to compromise for. Just like every other engineering choice you have made in your career. I suspect one of the major factors is cost.
It is actually pretty amazing (Scary) how much info can be gleened from power usage. My sister has two Tesla Power Walls in a rental in St John VI and it is scarry how much I can figure out about guest activity just from the Tesla app. I feel like I am invading privacy every time I look at the App.I am geeking out. I use a machine to help me cough. From the power output I can see how many times I coughed.
This is a SLOW running spring. Ram pumps waste a lot of water.In the 1890 home falling water or a spring could be made to pump water to a overhead tank using water hammer. Hydram pump.
Agreed The other problems with ram pumps is they are very loud.This is a SLOW running spring. Ram pumps waste a lot of water.
This is the primary reason for the LARGE water tank up hill. A family of 4 would drain that tank in a couple of days if it was not constantly being refilled.
Yes.... but they are sure fun to watch operate!Agreed The other problems with ram pumps is they are very loud.
Lol I made one in the backyard wife wasn't happy when I put a water tank on roof and ran pipes to my obnoxious noise maker. But it was satisfying to pump water with waterYes.... but they are sure fun to watch operate!
