Also a great option for the OP, but I like breakers better for the odd occasion you want to temporarily isolate something. Also bare in mind the inverter already has a breaker for the total battery input.For my DIY batteries I use a Victron Lynx Power In converted to a Distributor with Mega Fuses for a 48v system. I assume this is an OK system/fuse for my EVE 105 100amp (surge) packs. One mega fuse per pack.
@Quattrohead I'm going to be updating my packs very soon, at that time I I'm going to move to double pole breakers, think you posted them. Will also keep the Lynx, great busbar and shunt attachment.Also a great option for the OP, but I like breakers better for the odd occasion you want to temporarily isolate something. Also bare in mind the inverter already has a breaker for the total battery input.
I highly recommend the midnite busbar enclosures for mounting. The 1000A one I have is probably too big for most people but they have a new smaller 500A one.Yes I had replied to crowz regarding PV disconnects and this got lost in translation. For me, MNEDC250 fully rated DC breakers are the way to go but around $90 when not on clearance, not a lot more than a class t fuse and holder, however you have to figure out an enclosure for them.
View attachment 232891View attachment 232892
@SilverbackMP has the 2000A unit for the spacing I think he has six batteries and mnedc250s.I highly recommend the midnite busbar enclosures for mounting. The 1000A one I have is probably too big for most people but they have a new smaller 500A one.
I have the 1000 amp one and it’s great.I highly recommend the midnite busbar enclosures for mounting. The 1000A one I have is probably too big for most people but they have a new smaller 500A one.
@niktak11 you mean something like this with their breakers?I highly recommend the midnite busbar enclosures for mounting. The 1000A one I have is probably too big for most people but they have a new smaller 500A one.
The one Brucey posted or this smaller one:@niktak11 you mean something like this with their breakers?
I did the same thing with the breakers and busbars you did.I like Midnite (Carling Tech) breakers and a class T fuse .
(Ideally the wire lengths on the front pack would be the same length as the back pack but I ran out of 1AWG x 1/4" lugs on the bottom packs and I had to reuse leads from the last build... It will be corrected when I add more packs. Bus bar will have better protection as well. )
So would you say Blue Sea 125 amp fuse with rated Blue Sea base per battery I would be good?
