Vegan.Omen
- Jan 2, 2021
- 10
Hi guys,
Great to be among you peeps, and share with you my goal. I bought a converted van which has an electrical system (see photos) and i would like to upgrade the batteries to lifepo4 from the 2 110ah wet leisure i have currently (which are only getting up to 12.5v stable charge when using a noco g7200 even after repair mode).
I have a few things i wanna say, so if you feel like helping, please ref the number so i know what we talking about (if i can be so bold)
1. I would also like to add some usb ports. the only usb it currently has that runs off 12v has 2 slots, 1 is 2.1a, the other is 1a. if i use both, it seems to stop, and then restart charging, like its not able to do both at the same time. im assuming this may be the cable? either way, cables are hidden behind the build so wondering how i can upgrade that without ripping the walls apart haha
2. i have 110ah x2 lead batts, i believe with my epever 30a mppt, coco g7200 shore power charger and sterling bb1230 that i have bases covered for the upgrade and was planning to build my own cells with a bms from overkill or the other guys which have low temp disconnect. Part a) do you think i should be ok with the current system i have to just put that in? Part B) Has anyone seen a good battery case they have built into or do you have any ideas as the current batteries are low profile (below the drivers seat in the van) and id like to keep them there if poss. Also, any ideas on heating them so they dont fall below 0 degrees as i dont wanna ruin them
Thank you for your consideration and apologies for the long ass post!
Solar love!
Damien
Solar love!
Damien
