Sean Steele
- Aug 28, 2020
- 95
I managed to get in on one of the products from one of Will's videos and now I'm not sure if I went too far. I got four 250W Santan Solar panels. That's 1000 watts total. I figured I'd connect them in 2S2P to keep the voltage under 100VDC that the charge controller is rated for. However, I missed the other spec on the controller that says Max PV Power for a 12 V system is 520W. Will the controller just not use the extra power or will burn something up? I assume I won't get the full rated watts out of the panels but probably between 700-800 watts on a good day.
Panel and SCC specs attached
