I need a torque wrench or two. Which is your favorite or favorites for solar applications?
WYtreasure
It's not happy hour, I'm just like this.
Thunder Basin Wyoming
I need it for assembling a solar system properly.
As best I can tell there are bar, click, click and digital ratchets, click and digital adapters and the screwdriver types fancied by gun folks.
I am looking for good quality. Perhaps I will get one for inch pounds and another for foot pounds.
Any links and feedback will be appreciated.
I believe this torque recommended by @HRTKD wrench is good:
Post in thread 'Lost on Battery/BMS wiring & config'
https://diysolarforum.com/threads/lost-on-battery-bms-wiring-config.31007/post-390323
Howevr, that digital torque wrench is pricey!! Not willing to spend that type of money, I use this Tekton and don‘t recommend it:
I use these heap Felton wrenches and have stripped several aluminum bolts, not on batteries because of it. I torqued my batteries with this, but l stopped before the “click“ on half of them because it seemed like it was too tight. I also use Tekton TOrque wrenches to torque lugs on tires and the lugs have loosened twice. I joke about driving my vehicles until the tires fall off, but I was just joking. Just don’t trust them. I have no way to calibraate them although someone recommended putting it in a vic3e and hanging weights off it.
This is the torque wrench he recommended:
Now I know why the link didn't work, it's because of the price.
Yikes, maybe I will edit my first post to say "almost cheap" instead of good quality.
Back in the day, when I was young and needed a $600 tool, I bought it and still have it. Nowadays I don't buy so many of those.
The most versatile is the 20 ft-lb to 100 ft-lb 3/8" drive type. A 1/4" drive model can handle the smaller torques.
Be sure to always unscrew/ back off the spring after using, otherwise it will quickly lose it's calibration
Great advice about backing off the spring.
Looks like a decent tool I could use on my 85 Chevy as well. :)
Just looked at the 1/4" model:
I thought about starting a chat but knowing I would say something like "Where's the BEEF?" I decided to wait.
Yep, wires/nuts/connectors you name it. Whatever it takes to put together a solar system.
15 inch pounds to start, maybe 30 foot pounds to finish.
I will probably end up with two.
I have had good luck buying used torque wrenches on ebay.
I look for Snap-On, Klein, Proto.
Found a really nice, recently calibrated Snap-On inch pound, 1/4”, click-type
to use for the battery bus-bar bolts, worked great.
(Bottom in photo)
Sweet, nice lead (y)
Used torque wrenches are often out of spec, let alone being certified.
Buy a HAZET, the best tool maker around, all made in Germany. It's what they use in aviation, space tech, and a few high end auto makers like Porsche. This wrench would be a good fit for smaller applications:
That's one pretty wrench.
Thanks
I get Snap-On torque wrenches. 1/4" and 1/2" digital, 3/8" click. My brother is a dealer so I get a better price than most.
Snap-On wrenches found at pawn shops can be recalibrated. Take it to a Snap-On dealer and he'll either verify the calibration on the truck or send it back for a fully certified recalibration.
I have some nice fancy Snap-On torque wrenches that are electronic as well, both in 3/8 and 1/2” drive, and also do angle which I needed at the time for one of my cars (that sounds like I have a ton of cars haha, I dont). But they’re amazing!
for finer/lower details I have a 2-16nm, 1/4” drive from Effetto Giustaforza, it’s beautiful in its own right.
then for the finest precision, I have a couple Wera screwdriver torque wrenches for fine tuning tenths of a nm.
I like tools :)
with that being said, I do believe you can get some fairly decent torque wrenches at some low prices. You don’t have to buy snap-on to get accuracy.
I like tools :)
Thank you for the information, I will take a look at those nice ones.
I bought a Wheeler Digital FAT Wrench, 15 to 100 inch pounds, 1.7 to 11.3 Newton Meters. It came with a calibration certificate which is cool.
I assume the calibration certificate numbers are just like using the "Compass Deviation Card" numbers?? Yes/No/Maybe so
Would something like those be fine?
Fix It Sticks Tightening +/- 10% Accurate 15-65 inch-lbs All-In-One Torque Driver Tool Kit w/T-Way Wrench Bits Socket Adapters https://a.co/d/4rZO6fu
+/- 10% accuracy may not be good enough considering that the low end of the range is only 15 inch-pounds. I'm trying to recall how much I tightened the screws in my cell terminals and I think it was maybe only 12 inch pounds.
Guess it depends on what you’re tightening. I tightened my EVE cells to 6Nm.
6Nm is 53 inch pounds fyi
