I need a torque wrench or two. Which is your favorite or favorites for solar applications?
I don't trust the click type. For the battery connections, a small beam style worked for me.
For larger bolts, I like the Warren & Brown Torque Wrench. It is a beam style with an audible click. Unfortunately, they are Austrialian, and hard to find inthe USA (I bought mine off e-bay).
Anyone have a suggestion for a good single wrench for all solar applications that won't break the bank?
In general, you probably need two. One for the really low range and one for mid range.
So try to determine your specific applications/products to understand what torque ranges your install will require, especially on the lower range (less than 15Nm). If you don’t need the lower range for your install then you can get by with just one.
I used a coupe of click wrenches like this for smaller torque jobs nd the "click" was not very pronounced and I'd miss it.
Of the two, I'd use this even though I've not used one. I actually prefer analog gauges for these small torque jobs, so I'd liek to be able to see what the actual rating is or if this gives an audible beep, hear that.
(y) Yep... you have to 'feel' it... see my posting here (and the sad image above it)
The reviews do say the analog one has a very quiet "click" so I guess a bit risky to go ahead with that one.
I'll go with the digital adapter as you've suggested and will get the YR1035+ you recommended a while back.
Thank you.
