Hello. I am new to solar power and need advice and help with my problem. I have a Property in Philippines. we have power supply to the house by the Grid. 220 V. The Problem is Power cuts. We can manage without power for most of THINGS. BUT WATER SUPPLY IS THE PROBLEM. the system we use to feed the house with water. is done by a ground filled 2500 litre water storage tank. then we pump water into a Bladder tank. the pump fills the bladder tank about 12 times per day. depending on the demand from the house. I would like to operate the water system when we have no power by Solar power or to run it on solar all the time. can anyone tell me the best way to do this and give me a rough idea of the cost to install a system. I can if its cheaper and easier lift the 2500 litre water tank to a Hight that will give gravity presure. hopefully someone can help with this problem. I do not have a lot of money to spend. so need to look at the best way to do. Many thanks.
