ghostwriter66
"Here - Hold my Beer"
I need recommendation for 100A 24V 16S BMS with Bluetooth.... THX
24V and 16S are incongruent.
If your intent is to use a BMS on a 2P8S battery, you only need a single 8S BMS.
If your intent is to use two separate 8S batteries, you need a BMS for each 8S battery.
If your intent is to have 2X 24V batteries in series to form 48V, simply get a single 16S BMS.
Yeah I was hoping for a miracle ... wanting to only use one BMS - totally knew it was not going to happen - just thought that maybe someone had heard of something weird ..
Overkill at 200 amps, but I've just fired up one of these and it works quite well.I need recommendation for 100A 24V 16S BMS with Bluetooth.... THX
Excellent ... will follow up to see how they work ... we found the factory where I think that OVERKILL is getting their stuff made and its basically about 60% less ... i want to test some out when they finally get here to see if it is indeed the same .... i don't mind getting clones - just as long as the clone is not crap ..View attachment 87749this is jbd new bms it's a 24 or 48v that has automatic detection of strings. I have some on order just not sure how they work yet. They were just released.
I wonder if this would work on a telsa 24 volt battery ? I curious how your implementation works out. How long until delivery ?View attachment 87749this is jbd new bms it's a 24 or 48v that has automatic detection of strings. I have some on order just not sure how they work yet. They were just released.
If you find the actual factory, let us know. I know that several companies are related, but don't have a clue which is the actual owner/designer.Excellent ... will follow up to see how they work ... we found the factory where I think that OVERKILL is getting their stuff made and its basically about 60% less ... i want to test some out when they finally get here to see if it is indeed the same .... i don't mind getting clones - just as long as the clone is not crap ..
