lotsofsparks
Hi guys I'm having trouble designing my off grid solar system.
Issue 1# where do I put circuit breaker and isolators?
I have had 2 120A CBs tripping at only 70amps that have destroyed my solar charge controllers by disconnecting the battery While leaving my PVs connected.
Can I trust my BMS to protect the cables beween the MPPT and battery?
I have great concerns over unprotected low resistance batteries and cables.
Issue 2 I have 3 batteries (2 x 100AH and 1 x 280Ah lifeo4 12V) that aren't supposed to be connected in parallel or series with each over according to the manufacter's instructions.
should I get a 300A double pole triple throw switch or an interlocking relay system either one even exists to change between the batteries using 1 inverter on standby?
should I use an ATS switching between 3 inverters and a generator on standby an exept the power drain?
