I need some help with my Schneider System
It currently shows all the correct names but those names are greyed out and I am not allowed to change or add them as I could when they were valid.
Mine are grayed out as well and set as they should be. If they show the correct values, thats probably ok. Perhaps need to be in standby to change? I cannot remember how i set mine, almost certainly before commission or with inverter in standby (which i used to do for every change).
The answer is likely explained in your InsightLocal status area (as previously mentioned). The overview flows are pretty but they are often slow to react and show only a small amount of what is happening.
All well - the system was approved by the power company today. Thanks everyone for helping me. I sure educated myself a lot with this Schneider system.
My system seems to work but I see a very strange picture under the InsideLocal battery summary. What may be wrong if you look at the picture below?
At the point the current cycling begins the voltage appears to rise about 0.6V. Are your batteries topped off at that point? Doesn't seem like a high enough voltage to be tripping the BMS into protect u less these batteries are 15-cell LiFePO4. This looks a lot like something the XW charger setting could be doing if they're too close Later in the day you can see if isn't just consuming battery, it:a recharging too. First test would be to disable the XW changer.
What you mention happens every morning when the batteries - which discharges a little bit during the nite - are charged to the limit I have set of 51 Volts. The BMS has a much higher value and should not affect the values you are seeing. Yes I have 15 batteries. Is AC or DC coupling an issue here? I use AC at this time.
