I'd just roof a shop in at that point ?You could even mount them to said wall, works out perfect! ?
True, but might have less building codes if it doesn't have a roof.. then it's just a sturdy fence.I'd just roof a shop in at that point ?
Building codes, hahaha you're obviously not familiar with local government in rural East Tennessee ?True, but might have less building codes if it doesn't have a roof.. then it's just a sturdy fence.
"Where we're going, we don't need building codes."Building codes, hahaha you're obviously not familiar with local government in rural East Tennessee ?
If you mess it up, it not local government's problem where I reside."Where we're going, we don't need building codes."![]()
Free? I was under the impression he charges to do YouTube reviews. Something about wasting time on crap that won't sell...Of course.
It would be free advertising.
The trick is to not send him crap. lolFree? I was under the impression he charges to do YouTube reviews. Something about wasting time on crap that won't sell...
Should fit 10. I think it would be fine with the weight but I'd probably add some bracing if I really start pumping up the numbers. I've already got some beefy cross braces for holding up the batteries.Wow! Looks like you could get nine or ten batteries in that one cabinet. Will it handle the weight? What about the ampacity of the bus bars?
I believe some other larger scale parallel battery solutions have the master manage the overall current...balancing among parallel units.
Why does it only support 3 in parallel? gsl-051280a-b-gbp2 (which is similar with internal busbars) supports up to 16 in parallel. Any ideas? Are these meant to be daisy chained?I didn't realize it until last night, but I think this battery is pretty sweet. The look, form factor, busbar with quick connectors, communication ability, internal heaters, outdoor rated and the list goes on.
Now I want to dump my server rack batteries. Which one would you rather have. This setup:
Or four of these:
I just love the look. I love sci-fi movies and I want to make a system that looks really cool. I'm thinking four batteries and an 18K would do everything I need.
The communication set up was a bit difficult. I should probably make a setup video for beginners. I think anybody could figure it out though if they read the whole manual. I think there should be a tutorial on designating the master battery right after the communication protocol set up.
But besides that, this battery is pretty impressive. I'm going to be asking all of the other companies why they don't have this type of battery. Hopefully we can get some healthy competition into the market.
What do you guys think. Is there anything that you dislike about this battery that I'm missing? I really didn't think I was going to like it but seeing it in my shop in person, makes me want only these batteries now. I think I might move my server rack batteries into my garage today. I only have two power pro batteries but I could run everything I need with them. I'm almost at 5 megawatt hours with my 18K, so I really don't need to push tons of loads through it anymore. Making a beautiful system would be fun. I want to add LED lights behind it and make it pop![]()
Would GSL be safe in 4 or 6 battery configuration or would you go with externally fused busbar for those too?It's because of the connectors and cables, I think you can add more but must use external busbars and associated cables rated accordingly.
I'm no EE but I think what you're missing is on a setup like mine there are two distinct types of BMS's in each completed assembly...one in each individual 4.8 kWh module that manages the cells (standard ops) - and one that manages the current in/out of the stack of modules along with module level "balancing" (if you want to call it that). All 300A coming into the assembly goes through that "stack BMS" through a single connection. When you parallel stacks the master stack BMS knows how many stacks & modules are in the entire battery "array" and communicates current/voltage requests with the inverter(s) on behalf of the entire array and controls the slave "stack BMS's" to keep the entire array "balanced".Series cells, balancing is the BMS job.
Parallel batteries - what scheme do you think adjusts current draw or charging between them to ensure both are at the same SoC?
I could see multiple BMS negotiating the lowest charge rate so none gets a runner it can't handle. But beyond that would require high power switching circuits for the entire current, I think.
Yeah if it is complete and utter trash and I assume there will be zero affiliate link traffic, I charge a ton these days. After getting shocked, burned and cut trying to open some of the cheap solar generators, I started charging them. The garbage products are great for education though because I want to show people what they get if they don't buy the good stuff. And with electronics, there is a huge difference hahaFree? I was under the impression he charges to do YouTube reviews. Something about wasting time on crap that won't sell...
Great DIY, but a lot of people find it dangerous.Nice! One of my raw cells systems is still running:
The videos didn't get many views so I stopped making DIY raw cell systems. I really wish people shared those videos and got more views so I can make more of them. Oh well. I have to do what the people want.
You say that like it's a bad thing ...Great DIY, but a lot of people find it dangerous.
AgreedGotta say, I don't like the topper. Looks like an afterthought.
