Can't measure.
Or cut straight
Or see straight
Threads I can strip
Bolts I can break
Welding was a big mistake!
Pictures may be worth a thousand words, but I'm still at zero and could use a narrative.
So the next problem is to mount the bezel mount, right?2000 Series Bezel Mount Kit
Hoyt Meter's 2000 Series Bezel Mount Kit is die cast black with positive locking tabs works with our 2018, 2025, 2026, 2035, 2036, 2045, and 2046 panel meter series. Kit includes mounting hardware.www.hoytmeter.com
Like a self-rimming sink, the bezel is supposed to cover your rough hole.So the next problem is to mount the bezel mount, right?
I thought SMA Sunny Boy attachment points were weak....Two 5/16 bolts in the lower housing?? Fabbed a strap to the superstruts for the upper part........
What do you think?View attachment 24740
The box on the left melted under the cutting wheel of my Dremel tool.
The Dremel feels so awkward to me I can't decide which hand to use it in.
The walls on the box on the right are too thick for the chosen strain relief so its worse than useless.
