Hi. Have someone here experience using a "Ideal Diode" commanded as a relay?
I want to use it as a commanded switch (instead a contactor) since it has ideal performance for high current (more than 200 Amps and a incredible low loss due to the ultralow internal resistance (0.4 miliOhms).
I plan to command the module through the ground pin, and The mosfet should switch off.
The great adventage over the contactor is that the mosfet module has not "internal current" when activated (any contactor has several amps lost just to keep the contacts in ON position).
I have ordered a pair of modules to ALIX, but it will take some weeks to arrive...
So, any previous experience will be wellcome
