Hi, I am in the planning process and my goal is to eventually cancel utility service. But there might be an interim period where I need to run both utility and AIO Hybrid together as a whole home UPS. I will be running 1 Growatt 10k (ideally 2 future for redundancy), and 30k of battery. I have no plans to sell back to the grid.
I ran a clamp meter on the main line from the meter and turned on everything possible and got peak ~60 amps per line, 45 running amps.
I am considering replacing my 125A breaker panel, currently the meter is built in to the panel and there is a 10 inch jumper wire from the meter base to the main lugs. it's outdoor, flush mount in stucco with overhead drop thru the roof. How can I best take advantage of the AIO inverter wired as a UPS, and program the inverter for power routing, ie prefer solar/battery over grid.
For the AIO to run as intended it should be in line with the meter and panel so it can decide what is best, Im not sure what is the easiest way to do that. It would seem maybe a separate stand alone meter enclosure would be better and then run through some sort of single breaker junction box to the Growatt, then back to the main panel. Any ideas for brands or specific models is greatly appreciated.
