Lenny's OffGrid RV Living
In the past year or so, I acquired 2x 100ah AGM batteries as part of a Craigslist package that I bought ($400 for NIB 3x 100watt solar panels, Renogy PWM charge controller, MSW inverter, cables, wiring, and the two batteries). I'm not using the charge controller or MSW inverter. I have 1,200 watts with 600ah of LiFePO4 as my primary system but have a smaller 2nd system with the two 100ah AGM batteries. Right now, I have the main system on tiny home and the small system on my travel trailer as I repair/renovate/make road ready.
My plans are to put the main system on the TT once it is done and ready, then I'll technically plug the tiny home into the TT system. I'll put the small system on the tiny house so it will have some power when I'm away from basecamp (to run security system, etc.)
Do you all think this is the best plan or would I be able to use the smaller system also on the TT to give me even more power and then just plug the tiny house into the grid when I'm away from it. Yes, I have grid power as a backup but mainly live off of my off-grid solar systems. I also have a rental tiny house that needs grid power which is why it's also available to me if/when needed.
Thanks in advance.
Thanks in advance.
