Identify lifepo4 vs ternary
Saks
New Zealand
Hi, I can get a battery set out of an electric truck and wanting to use it to build a golf cart battery.
They are being sold as lifepo4 90ah 3.2v but someone mentioned they could be ternary which wouldn't suit a golf cart from what I understand.
Is there any way to identify which it is from pictures? I have attached hoping someone can confirm either way. Hoping I can use them as they are well priced and local.
If they are good to use, the busbars are riveted and will need to be reconfigured to suit my voltage but that is easy enough. Just want to make sure they are suitable before I commit...
Yes, but I can't quite read it... I have attached
Yeah, doesn't look like some common Lifepo4 QR codes we usually see.
So a bit hard to decipher.
But, judging by the bus bars, this pack is a 2p7s. 7s is somewhat uncommon for Lifepo4 packs, but pretty common for Ternary Lithium, giving a nominal voltage of around 25v.
So probably is Ternary...
The seller has advised that the charged voltage of the cells is 3.55v which makes them look like lifepo4. I just really want to be sure before committing to them
