Not Aerosmith
- Sep 8, 2022
- 389
It seems that an automatic transfer switch (ATS) would activate the existing grid-tie inverters when the grid is up and work as originally installed. Therefore, an ATS could activate an off-grid inverter when the grid is down.
Since neither inverter works at the same time, it seems that the same solar panels could be connected to both inverters. Although, I believe that I need to add a relay to disconnect the solar panels from the off-grid inverter. Upon loss of grid power, the relay closes and the off-grid inverter is connected to the solar panels.
The advantage is that instead of a gasoline driven generator as backup power, we could use a solar driven inverter as backup power. In my case I would probably add 5 kw off-grid inverter with 10 KW of batteries. My current grid-tie system is (3) 5 KW inverters with 57 solar panels and no batteries.
My existing grid-tie system works great, so I don't want to revise it with new hybrid inverters not fully debugged or only works with a critical load panel. I want to add a second system for whole house backup power. Any reason why this shouldn't work? Any affordable suggestions?
