I plan to install EG4-18k at one property. I will use whole house backup wiring, which means connect my main 200A panel directly to the Load. Like in the picture 1.
I noticed there is another way to connect the main panel: With a Bypass transfer switch. See below two image:
(1) With a Bypass transfer switch
(2) With out that Bypass transfer switch.
My question is: What's the purpose of that Bypass transfer switch? Does that means if the EG4 fails, I have to manually push that Bypass transfer switch in order to get rid of EG4 and let my main panel energized?
In another word, my question is: If I do not install that bypass transfer switch, and if the EG4-18k fail (for whatever reason, defect, lose power, malfunction etc.), will my main panel still be energized?
I though there might be some mechanism in the EG4 to connect the Gird port to Load port directly in case the EG4 fail, but I could be wrong.
