Hello all,
I have a 40' skoolie. I finally got my solar system installed and operational. I love it.
My question pertains to the correct size of the wires and how I should ground them between the DC fuse block and LED floodlights. Right now my system is grounded to the chassis of the bus from the shunt.
I have 4 LED floodlights that use 1.5amps each. I want them all on one circuit and I have two switches to turn them on/off. One switch is at the entrance to the bus and the other switch is 40' away in the rear of the bus. The electrical components are near the rear of the bus as well. The floodlights are place on the exterior of the bus, one on each corner, so the wire run between all the lights is about 100'. So from the DC fuse block to the switches and then to the lights is at least 160'. I'm looking at the wire gauge chart and it recommends using a really thick wire...like at least 8 awg.
So a couple questions I need answered...
1. Can I ground each light individually to the metal ribs of the bus to cut down on wire length? (Instead of running two wires between each light, I'd just run a + wire between each light, and the ground wire would only need to be a few feet to get to something metal on the bus)
2. What can go wrong if I just use 14awg for this circuit? Will the wire melt? Will the lights be dimmer because of voltage drop? Do I really need to use 8-10awg for a long run like this?
Thanks for your help!
Matt
Matt
