Bud Martin
Solar Wizard
- Aug 27, 2020
- 4,843
Did you ever see it produces a lot more power before or it has been like this from the beginning?When using LI mode, which means the Growatt Inverter is talking (or rather listening) to the EG4 batteries, this setting cannot be changed. It's controlled by the unit.
When charging at a limited 25A (1.3kw) from solar, this value reads 50A.
What happen if you remove the communication between the Growatt and the EG4 battery and set it up as dumb battery?
