ghostwriter66
"Here - Hold my Beer"
So I say this after having hooked up well over 25 MPP Solar systems at work ... so this is not one of those bitching for no reason type things (well it actually is) ... BUT .....
The MPP Solar is an excellent system - until its not.
Until you need customer support.
Until you try to read one of their "ENGLISH" manuals.
Until you try to figure out why in 2022 they are still using Serial cables with RG45 connectors on the end (Seriously - have they never heard of a USB connector!!) ...
There's just toooo many lighter, better, faster, cheaper systems coming on board to go thru this MPP headache any longer ... Sure back in the day when MPP Solar was really the only "slightly better than the rest" I would defend them and basically say that there wasn't really a choice out there that we could all afford .. but there is NOW -- and several of them ...
Manuals are mostly wrong - you waste several hours trying to figure out what they actually mean
OMG their WiFi software WATCHPOWER is sooo bad its not even funny - you can't even see anything you need... and everything comes out in PDF format instead of Excel...
There customer support is random at best -- and typically they are answering a question that you are not asking.... Their first answer is always - have you read the manual -- if you say Yes then they say - well tell us exactly what the issue is (which we already had) .. then they send you a response involving UNICORNs and Candy but not a solution...
AGAIN - Who the hell is using a serial to RG45 cable in the last decade ?? -- did they find a huge supply from 1990 they have to use up ... ??? ZERO of our laptops out here have an RG45 connector to plug into ...
My list actually goes on and on .. but all I can say is - before you start drinking the MPP Solar Kool-Aid you might want to look around at other alternatives ... For me personally - I'm done -- your playing Russian roulette hoping that if/when your system has any issues - that someone on YOUTUBE has made a solution because I promise you support is zero ...
Again - everyone of my MPP solar's are still up and running -- BUT it has been an "ass-pain" to get some of them to do what they say they can do.
aaaaggghhhhhhh
aaaaggghhhhhhh
