Ok yes! So my charger will stop when its done charging with the settings you recommend. So once it hits the float stage it will only supply current for 15 seconds and just shut off again? So basically stopping charge automatically? Im bad at asking questions lol
Not exactly but you're close.
The absorb is the top voltage charge. When it hits absorb, if it has an absorb time, it will stay there and soak up the power at that voltage. This puts on a good charge. Its like letting a sponge soak up until its full... but based on time. Some battery manufacturers specify a voltage and absorb time. I think the SOK at 14.6V was over the top unless you needed to squeeze every bit out of your batteries (like you are trying to make your specs seem really high).
Once it hits that top charge, it will stop charging and your batteries will settle to their resting state or until they get down to your float voltage. The float voltage is like the minimum state of readiness of maintain voltage.
I think there are a couple different float strategies. If you are using your batteries all the time, like living in an RV with a fridge running and continually using power, then a higher float value is better. Something like 13.6V for example.
I have my RV in my driveway too much of the time. I have my float voltage BELOW where my cells tend to settle so that it does not "micro-cycle" over and over all day long. My cells settle to around 3.35V after a full charge. I float around 3.32V and it take several days for them to get down here so its not much extra wear and tear on the battery.
Make sense? There are different ways to do things and a lot of it depends on how you intend to use your batteries. And also on your battery beliefs. My battery beliefs are conservative. Some folks beat the crap out of their batteries and charge to 14.4V every day (a full time RVer) and thats great. He's been doing it for 6 years and is completely satisfied.
So keep that in mind. Set your settings conservatively. If they're not doing what you like or want, come back here and tell use whats up and we'll see if there are things that can be changed to meet your goals.
Start conservative. Lower all the high voltages down to 14.0V and sleep assured at night. Turn equalization off and equalization time to zero just to be sure. Set float down to meet your state of readiness (ask if that was not clear above). 13.4V if a good conservative float, 13.6V not outrageous either.
