immortl
I have an immediate need to replace old, worn out, last only 6ish hour 12V lead acid batteries on the current solar system. The current inverter is an older 12V AIMS 3k (need to sort out which exact model it is). This property is fully off grid (but has high speed fiber!) and with TV usage (more so my significant other) and my work from home laptop/monitor setup, along with internet router and cell extender, the current batteries (10 6v golf cart lead acid from 2017) last me about 5-7 hours. I'm basically running generator for most of every day/evening.
I have most all the parts for the new full on Victron dual Quattro 10k 48v 52 400 watt bifacial panel system but it's going to take me a bit to build the new electrical shed (going ICF for it) and excavate the 3 solar pole mount foundations and trenching, etc...
To bridge the gap, I'm thinking to toss in 2-4 12V LiFePo batteries. Seems the AGM charge profile on the AIMS unit will somewhat align with 12V LiFePo charge voltages. the AIMS states the AGM profiles are 14.1 charge / 13.4 float and 14.6 Charge 13.7 float. Looking for something decent, thinking I can give them to the very nice, very helpful neighbor when I'm done with them as she is starting to look for some new batteries but doens't have a whole lot to spend. After some quick searching, I am considering Eco-Worthy 12V 300AH. Anyone have any thoughts on these or any other suggestions? Looking for something I can order and swap in ASAP.
Figuring I'll probably toss some of my 400W panels up against a fence rail and use one or two of my Victron 250/100 to add to the solar array as well. The current array consists of 6 100w panels tied to assorted fencing. It's 'interesting'.
Thanks!
Thanks!
