Well, you want to get the cells balanced before comparing too carefully, but those three {3,8,14} have some serious issues, I'd check the connections, disassemble, clean, and reassemble with the correct torque, etc.
Check every single cell without busbars....Bad connections are the most common address to search for.I found a bad ac connection the other day,which carbonized some centimeters of cable....With those heavy busbars,I can imagine the sparks
