I do have a 1.7l 120VAC 1100W kettle, and I use it regularly.
Did you guys know our north american countertop appliances are pitifully underpowered compared to what consumers on the 230v systems enjoy?
Sure voltage isn't necessary for wattage, and we could have 30 amp 120 volt appliances but nobody has those outlets so they don't make them. Whereas in 230v countries, 15/16 amp countertop outlets are common.
Amazon.co.uk will ship internationally for a reasonable rate, and 3kw kettles are common and cheap there.
You can go NA style and change the plug on the kettle cord to a 6-15, or if you'd rather enjoy the full international experience Leviton actually makes a UK outlet that fits in a NEMA box in a decora plate.
BSRDP-W
White - British Standard Receptacle, 13 Amp, 250 Volt, Decora, Tamper-Resistant, with Double Pole Switch, Integrated to the Circuit, to Cut Off the Current On Both Contactswww.leviton.com
Either way you just wire hot to hot, and what would be the british neutral to the other hot. Is that dangerous? I don't think so, because neutral is still protected and the kettles use a separate EGC. But it's probably not completely kosher by the UL listing either.
If you don't have an electric kettle and wonder why, they are good for making pour over coffee, tea, or heating some water up for a pasta pot faster than it would boil on the stove.
It brings me joy every time I press the button to hear 3kw click on.
Uh ... nobody else uses a laser to heat their water/coffee, in a few femtoseconds?
www6.slac.stanford.edu/news/2018-05-15-scientists-turn-x-ray-laser-worlds-fastest-water-heater
That's just a little camping kettle 1.1kw lol! I've got one in my tent
Also try toasters
life before & after the ✨ Kettle ✨ ? | life before & after the ✨ Kettle ✨ ? | By Yorkshire Peach | Facebook
life before & after the ✨ Kettle ✨ ?fb.watch
An American lady who's moved to the UK
I microwave my water,
At 90s of microwaving, there isn't enough energy to superheat the water so I don't worry about it. You don't want to boil the tea leaves, you just want them to steep. In the south we have sun tea. Although it's actually a myth ... the sun just makes the water a little warmer so it goes a little faster than if you just leave it in the fridge without sun. Really this is just slow brewing and it takes a few hours. How long it takes depends on how dark you like it (don't add lemon in advance, lemon lightens the color). Some people swear by it, but it's probably because the tea is a low grade and full of bitter tannins. For your expensive teas, I would use hot water. |
Sun Tea is actually a myth! |
If you want to impress your friends and are willing to shop on Amazon U.K. to achieve it, go for a 3kW water dispenser instead. It makes a single cup of properly boiling water in 45 seconds, lights up blue inside and everything…. Your friends will love it ?Did you guys know our north american countertop appliances are pitifully underpowered compared to what consumers on the 230v systems enjoy?
BSRDP-W
I've got a 3kW kettle and a 430kW car. (EV)I live in the UK and use a slow kettle. 240VAC at 900watts. It is actually made for caravans but works a treat during sunlight hours. Usually costs zero money to boil whereas the old 2.2Kilowatt beast would sometimes use grid juice. Whats the rush folks? The kettle takes a little longer to boil but whats the rush? Same folks who drive a car like a looney i reckon.
lol forum created by an Aussie and stalked by Brits.What the heck, is this forum full of Brits!
I have not tried "Lucifer" with Tea, but he sure as heck can cook steaks within seconds.
Texas toast
My 240v kettles in Asia will bring water to a boil in about a minute.Yep. The colonizers will readily point that out. My experience is different.
To put this exercise in context, you save about 3 minutes @ 230VAC vs. 120VAC.
