Does anyone have a useful hack as to how I can search for solar panels by specifying either volts or amps that I'm wanting. (Trying to pair up different wattage panels.)
(going to be purchasing 2 panels, but lets focus on the individual numbers...)
Aiming for as much wattage as possible in a panel that is no bigger than 56"L x 35"W. (of course these dimension limitations will determine the wattage for me)
I'm trying to pair them up with 2 :
STCrated Output Pmpp (W) 440W
Module Efficiency 20.21%
Open Circuit Voltage VVOC (V) 49.9
Short Circiut Current ISC (A) 11.33
Rated Voltage Vmmp (V) 41.0
Rated Voltage Immp (A) 10.74
I have not purchased the two 440w panels yet so the wiring schematics can be done anyway that works with the additional 2 panels.
Does anyone have panels that you can share the name brand and wattage with me that either match my V or A, or will match when put in the array. I'm hoping to not loose any array efficiency (or as little as possible).
Thanks guys!
Thanks guys!
