gribbly
- Mar 4, 2022
- 7
Hello all, first post - new member in Seattle!
I'm hoping to talk through designing a solar rig for Burning Man. We've been running a ~5kWh solar rig using SLA batteries for years at Burning Man, this year we want to upgrade to lithium (the SLA batteries are getting very old and we don't want to buy new lead acid).
I don't have much experience with Lithium, so I'd appreciate any guidance and sanity checks!
We calculate our power needs at 11kWh/day. Most days will be less than this, but we'd like to be comfortable on peak days.
The cost of this project is shared across ~40 people, so I don't think budget will be too much of a constraint (although obviously cheaper is better!)
I would love advice on constructing the battery bank especially (I feel pretty good about the panels/charge controller side of things)
Here are questions I have about the battery bank:
What else should I be thinking about?
- I think I should go for 24 or 48V batteries, so the wiring can be lighter. Is that the right approach? Seems like 24V is a sweet spot between cost and efficiency? I was thinking of maybe using something like these batteries: https://www.amperetime.com/products/ampere-time-24v-100ah-lithium-lifepo4-battery
- I don't know how to think about a BMS. Do I need a BMS in addition to the charge controller?
- Would those Ampere Time batteries do OK in desert heat? We can shade them from direct sun, but ambient temps will be hot (100 degrees+ probably).
