Copper grades
C101 - 99.99% copper 0.0005% oxygen, high electrical grade
C110 - 99.90% copper 0.04% oxygen, most common
C122 - 99.90% copper 0.02% oxygen, deoxidized with phosphorus, most copper tubing and pipes
You will not notice the difference between C101 and C110 in bus bars.
Nickel plating should be used to prevent inter-metallics galvanic interaction with aluminum cell terminals which can erode and pit aluminum surfaces over time degrading terminal connections. The nickel plating degrades bus bar resistance by about 10-15% but long-term benefit outweighs degradation.
Best realistic connection resistance for each cell terminal is close to the same resistance as the copper bus bar with nickel plating and is about 0.05 milliohms. Typical nickel-plated copper bus bar is about 0.07 milliohms, so you get 0.05 + 0.07 +0.05 = 0.17 milliohm resistance between cell terminals.
Beware of nickel-plated brass bus bars provided by many cell sellers. They are about 0.2 milliohms just for bus bar.
